early 325e 5speed to 89 325i
  • kamotors
    • Nov 2007
    • 7102
    Newb question....
    I'm about to pick up an 85 325e from a friend for cheap. I getting the car mainly because it is a 5 speed. I plan to swap transmissions with my current 89 325i. Will the early model 325e transmission bolts right up to a late model I car?
    7speedshop.com
    That transmission will swap into your car.
    • kamotors
      • Nov 2007
      • 7102
      thanks, should be 5 speed in a few weeks than.
      7speedshop.com
      • Wishno87
        • 6025
        You probably don't want that tranny. 85 only has mounting provisions for the sheet metal console. 86 has both.
        • siggy
          • Oct 2009
          • 336
          If it is the early style tranny without the cast-in mount for late model aluminum arm shifter type, you can use a oem BMW M3 part that allows for this exact scenario.
          Part # 25112225369 (#2 in the diagram)
          http://www.realoem.com/bmw/showparts...81&hg=25&fg=05
          • Wishno87
            • 6025
            +1 I forgot about that part.
            • kamotors
              • Nov 2007
              • 7102
              discovered the 325e is an 84, is it still the same trans?
              7speedshop.com
              • Wishno87
                • 6025
                Should not matter.
                • F34R
                  sLaughter
                  • 12376
                  You'll be fine
                  Instagram: @BWeissLeather
                  Current cars:
                  ~ '87 325 M30B35 swap
                  ~ '87 535
                  ~ 01 540 Msport 6spd
                  ~ '06 X5 4.8is
                  • BMWerke
                    • 893
                    on friday i am swapping a 5 speed from my 86 325e parts car into my '90 325is, it should be interesting
                    '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
                    '86 325e- Donor car for swap/parts car
                    '00 323i- BBS 197s Totalted
                    '89 740 turbo Volvo- Donated
                    • Sagaris
                      • Sep 2009
                      • 2243
                      Kamotors, have you started your swap yet?
                      • mkcman17
                        • Jul 2010
                        • 8240
                        i made this mistake, the tranny wont swap.
                        the output flange is different and will NOT match up.
                        1989 LN106 Hilux / 3.0TD SFA
                        1974 2002tii / stock
                        2002 IS300 / 5spd LSD
                        • Wishno87
                          • 6025
                          Depends on what year eta tranny you are using. Some had the big output flange.
                          • mkcman17
                            • Jul 2010
                            • 8240
                            If it's an 84, it's not happening...
                            • kamotors
                              • Nov 2007
                              • 7102
                              really? what have the others been doing, I have not started the swap yet, I bought a wrx instead.
                              7speedshop.com
