Loud clunk in Reverse
  • akinswonder
    • Nov 2009
    • 177
    I have a five speed. And whenever I back up I here a loud clunk but this only happens in reverse, also the clutch doesn't have to be engaged even when I'm in neutral and just backing up I still here the clunk. All other gears shift smooth and work just fine. Can it be a driveshaft problem or what?
  • IRON-E
    • 16548
    rear axels?
    @IRON-E30 aka Edwin:D
    • akinswonder
      • Nov 2009
      • 177
      Originally posted by IRON-E
      rear axels?
      Thanx, wut makes u think that it can be the rear axles
        This could be bad transmission/motor mounts, wear in the drive shaft, wear in the differential, bad half shafts, bad trailing arm bushings, bad subframe bushings, bad differential bushing or a combination of faults. A through inspection should reveal likely causes.
        • Holland
          • Nov 2008
          • 7204
          Lol, mine always klunks when I shift into reverse unless I do it slowly, always thought it was the nature of the beast.
          Originally posted by DEV0 E30
