No fluid bleeding from slave cylinder?
  • flipdsm
    • 15
    My clutch works fine, pedal works fine as well. I just decided to bleed the slave cylinder one day just for fun. I cracked open the bleeder screw and NO fluid came out, even with the clutch pedal fully depressed. I even took the bleeder screw out completely but still no fluid. Is there something wrong with my slave cylinder? Again, my clutch and pedal work great, no fluid leaks from master or slave cylinder and lines.
  • BimmerTim
    • Oct 2007
    • 613
    It's plugged.
    I had that happen to some brake calipers. I pulled the bleeder screw completely out and jambed the brakes as hard as my thunder thighs would allow, but no dice.
    If it works, leave it alone. If it bothers you, replace it.
    1988 Bronzitbeige Metallic 325e 2-door S50 turbo (OO=( )=OO)
    2008 VW Rabbit
    1991 Audi 200 20vtq Wagon
    • InfiniteDice
      • 5
      Well take the bleeder screw out, and stick a sewing needle in the hole in a sexual manner... I'm sure the little bit of rust particles will come out just fine :)
      • Conrad311
        • Oct 2009
        • 370
        yea i had that problem, so i put the nose of a gear lube bottle on a can of brake fluid and put a hose on the bottle and the bleeder, and did a ghetto rfi and it worked fine
        "In God we trust. All others must bring data." -W. E. Deming
        /// 1987 325is /// Project Thread
        Past: 87 is, 88ix, 88 i, 87 ic, 89 ix, 17 others.
