I recently replaced the rear brakes and the guibo and CSB. I noticed driving home from work yesterday that there is now a womping noise coming from the right rear. It seems to lightly go away when i turn left. Also, when i depress the clutch, it seems that the whole car wants to jump around. I was thinking wheel bearing, however i wouldnt think that i would be able to feel a rear wheel bearing in the steering... Any thoughts?
Help!!! Noise from backend.
84 Henna 325e - 88 Delphin 325iC -90 Schwartz 325is - 93 AW740iL - 01 Titan 740iLSportTags: None -
when the right rear bearing got really bad on my e36, the wobble in the wheel would cause the car to veer left and right.
Originally posted by ROLLingKINGi have a bronzit and plan on making it look sweet.Originally posted by slammin.e28Moral of this story?
If you drive your e30 on stairs, you're gonna have a bad time.Comment
