fiff bushing help
  • spoolin6er
    • 4
    fiff bushing help
    *edit* - sorry for the fail title/typo.
    I got a welded 4.10 diff today from a friend, but he removed his old bushing for some reason. I figured I would be able to swap covers and call it good, but now that the diff is out it is obvious that that is not possible - # of bolts is different :(
    Wish had taken a better look before I took it out. Its a 3.73 open.
    Are these bushings serviceable? Meaning, can I press a new one in? Where would I find one?
    Also, while i'm here... I've got a weird ticking/rattle sound that varies with speed but is only really audible when coasting. If i get on the gas it goes away or gets much quieter. Any ideas? I'm a RWD newb :oops:
    A new bushing can be pressed in.
    • Dude
      • 1119
      I took mine out when i painted it, then hammered it back in
      • FredK
        • 14762
        I wouldn't hammer the bushing back in. You can crack the diff cover pretty easily, as it's cast aluminum.
        You can use a bolt and some steel plate to press the bushing back in if you're in a pinch.
        • Dude
          • 1119
          yeah thats probably the best way to do it for cheap
          • spoolin6er
            • 4
            What did you guys use to get the old bushing out? Some type of puller?
            Anyone bought a new bushing - if so where?
            thanks for the help!
            • Dude
              • 1119
              Just get it off pelican parts or something.
