Today i took the Z3 short shifter off of my old 1987 325i and put it on my 1990 325is and the linkage was hitting the driveshaft. My coworked decided that grinding it down was an easy solution to the problem but now a bigger one has occured. When i try to shift into reverse or 5th the linkage starts bending and the shifter will be touching either sides of the boot. Now i cant get it into reverse or 5th. is the linkage differrent between the two and who can i get the part from. Any help would be great
Desperate HELP Please
Tags: None
did you put it on backwards?sigpic
Levent
%20levent@gutenparts.com
Ladies:
1998 E36 m3/4/5 1988 325i 1989 325iT -
Let me understand this: you ground down the shift selector rod?
If so, replace the fucking thing first.Comment
Did you use the old selector rod knuckle on your new(er) transmission? Doing so would create the problems you describe (interior gears engage OK, exterior gears aren't right)
The knuckle that attaches the end of the shift linkage to the transmission's selector rod is different from early to late models...pretty sure your 87 is an early.
Late selector knuckle (centered):
Early selector knuckle (offset to one side):
sigpicComment
Hey buddy first thing is, your coworker is a DUMB ASS for grinding it. second put the old shifter back in it. If there is something wrong with the one you took out I would by an oem replacement cus it sounds like to me you have no idea on what your doing.sigpic
85 swartz/metallic 325E
84 alpine 325E
85 zinnoberot 318i/R.I.P
84 Bronzit 318i/sold
purchase feed back here=http://www.r3vlimited.com/board/show...82#post3535282Comment
JOY IS AN E30...
I recently switched my early model car's shifter to this setup - just finished 3 hard days on the track actually - and I've read about other people running in to the same problem having it solved with this piece. That's all I've got for supporting my idea about the knuckle being a problem. YMMVsigpicComment
no need to be a dick. I have a late model, but I ground mine and I have no problems in 3k miles. It's not really complicated or something you need to know what you're doing to accomplish. I wasn't comfortable bending my selector rod as much as needed, so I shaved off just enough to clear after a slight bend.1989 325is / 2.7, 274 cam, e30 M3 5-lug
1989 LN106 Hilux / 3.0TD SFA
1974 2002tii / stock
2002 IS300 / 5spd LSDComment
