Well I know this is a E30 forum, but we share one thing in common...M42. I own a 1993 BMW 318is and it is time to replace the clutch at 217k :) I read in your faq that all you need to get a lightflywheel kit is...325i flywheel, 325i clutch, 325i pressure plate, 325i drive-pinion for the starter motor, and a ‘78-’83 323 throw-out bearing. My question is my tranny is a Getrag S5D 250 G as production of the 200 was discontinued in 9/92 and my production date is 11/92. I may go underneath car if you need me to, for verification purposes. So my ? is can I use your guideline on my vehicle, and what year parts should i be on the lookout for? Also if you could point me to a place you recommend to purchase from I will do so. Thank you all so very much. :D
