Are all transmissions the same for e30's?
  • Drewe30e
    • Apr 2005
    • 171
    I think my synchronizers are going bad on my '85 325e. If I need to get a new transmission, are all e30 transmissions the same? Also, I doubt there are any used transmissions that would be worth installing. So, are there any good companies to get transmissions from that are either in good condition or rebuilt. What do you guys suggest that I do? It sucks not being able to go into 4th gear!!! :evil:
    1985 325e - 5000 RPM's of Fury
  • AdamF 88iS
    • 2051
    You can use any tranny from a 325 or 325e from 1984 to 87. 325i tranny won't work due to lack of holes for the flywheel sensors.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • Drewe30e
      • Apr 2005
      • 171
      You are completely right. I actually had a problem with the sensors a few months ago and totally forgot that it was only an early e30 problem. :roll: Well that solves that question.
      What about a place to find transmissions. I've been looking all over the internet, and I can't find anything of use. What would a good transmission be worth?
      • DEV0 E30
        • Oct 2004
        • 8904
        theeurodepot.com ~ ~$395.00
        There are other places, maybe you haven't checked that ^ yet.
        • Sean
          • 5793
          Getrag260's are most of the time bullet proof. You could find a used one for around $200 most likely.
          - Sean Hayes
          • Drewe30e
            • Apr 2005
            • 171
            Somehow I never found this site. Thanks for the heads up.
            Overall, would a used transmission be worth it, seeing how it could possibly go bad at any time too? Should I get a rebuilt one? I'm a poor college student by the way.
            • Sean
              • 5793
              Find a used one with around 100,000 miles on it, and it should be good for ya. Make sure it was used nicely though.
              - Sean Hayes
              • Drewe30e
                • Apr 2005
                • 171
                Sounds good Sean, thanks for the help.
