Delete
Delete
when you bleed it out of the trans you have to keep the piston from moving otherwise the piston will just pop out the end, theres not a stop in thereYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered. -
Some times you can just push it back in and it will stay. If the rod doesn't stay in and the boot is folded over it will probably start leaking sooner than later. when you first start to bleed the slave and it isn't in the transmission make sure the pedal is up all the way and just open the valve on the bottom and let the gravity bleed most of it for you. You will probably have to install it in the trans and then pump the pedal to see if air is in the master. Email me if you get stuck.
DevinComment
Down. There is an internal passage that draws from the top of the cylinder when the bleeder is pointing down to make it easy to bleed with it installed.
I have no idea who is having difficulty bleeding theirs mounted to the trans.... Rigging a way to hold the piston in place sounds like more work.-Dave
2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
Need some help figuring out the ETM?Comment
