Pressure Plate Bolts
  • JoeP
    • Mar 2005
    • 150
    I have an early eta with the single mass flywheel. Are the pressure plate bolts the same as the dual-mass flywheel? Real OEM doesn't list the part numbers for the single mass bolts so I'm not sure what to order. Thanks!
    • 37829
    Part # 07119919939 and there are 6.
    To answer your question though, yes they should be exactly the same.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • JoeP
      • Mar 2005
      • 150
      Thanks!
      • shiboujin
        • Feb 2006
        • 2791
        IIRC there are 2 length pressure plate bolts. I don't remember what flywheels had what though. Torque spec is 16-18 ft/lb FYI.
