Hello,
I have an 88 325is and I found that when I turn left I get some sorta humming noise and slight vibration.
I replaced the driveshaft last summer due to a bad u joint and center bearing and noticed grease/sludge comming from the axles where they enter the diff.
Im assuming its the axels however I dont want to spend 300 bux on a new set if that isnt the problem.
On the highway it vibrates from 85 to 100 then after 100mph it smooths out but if im making a slight left at any speed the vibration starts.
Car pulls to the left and only vibrates when im turning left but whenever I slightly turn right on the highway the vibration stops and everything smooths out.
Im not sure if it needs an alignment or what?? but I have new tires and like I said just changed the driveshaft.
I deleted the powersteering but I dont think thats the problem because even when I still had P.S it still drove the same besides having a looser feel.
I also noticed that on the highway I have choppy decel when I let off the gas.
I hope I was somewhat descriptive enough.
Please help I dont want this to turn into a bigger problem than it already is.
Thanks.
Thanks.
