Transmission Service Question.
  • Robert
    • Dec 2010
    • 3770
    Does anyone know what type of fluid should put ?
    I was told just ATF or Dextron 3 , should I put high mileage fluid or regular ?
    Anyone know what type of fluid I should put in ?
    This is what i plan on doing
    Drain all of the transmission fluid , including what's in the radiator .
    Clean the transmission oil pan ,
    Change the filter .
    Change the O ring .
    & add a new gasket .
    replace transmission oil fill tube , since mine is pinched
    & put new fluid .
    Thanks,
    Robert
    • 37832
    Standard ATF MD3. Don't waste money on "high mileage" fluid, it's all bullshit.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Robert
      • Dec 2010
      • 3770
      Thanks man ! I really appreciate it .
      Robert
      • 801coppertop
        • 293
        Depends on sticker or drain plug. If its supposed to be running a mtl fluid that atf will ruin syncros. From what I have read. Bentley explains in detail. But what kind of bolt does your car have to drain fluid?
        • SpecM
          • Oct 2005
          • 4531
          dude, he has an automatic
          OP: use Dex/Merc III
          1989 cirrisblau-metallic 325i
            • 37832
            Gotta actually READ the original post before you reply. ;)
            Grover Beach, CA
            www.BimmerHeads.com
            • bmwstephen
              • 2463
              are you pulling down the trans to do a gasket overhaul or just the bottom seals?
              • whodwho
                • Jun 2008
                • 1547
                Just making sure you know to check the fluid level while running with the car level and the fluid hot, it is easy to over fill it.
                My M20 Frankenbuild(s)
                4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                • StereoInstaller1
                  GAS
                  • 22679
                  Hmmm. Flushed all the crap fluid out of the E34 tranny, was damn near black. Seems to shift much better, but hasn't been "driven" yet, only 10MPH around the hood, and the car came to me dead.
                  All I am gonna say is this: you need to change all the fluid, ideally a tranny flush. If you can pull a cooler line off the tranny to drain more stuff, do so, but the torque converter holds about 3 pints or more. You ain't gonna get that fluid out without flushing. See if a local service place has a good deal on a flush.
                  Closing SOON!
                  Thanks for 10 years of fun!
