I need it as soon as possible i have paypal or i canpick it up locally. i found a picture of one online and did my best on paint to show you how mine looks like :D
r3v does not fuck around. First you get banned, then they shoot you
I saved the output flange off my auto e24. On the outward chance that these kind of things interchange, what are the dimensions of the flange you seek? Maybe one hole center to another?
what year is your e24 ill check on realoem like jlevie said
Originally posted by mattdk318i
Ive got one on a blown up 260 i have.
PM sent
So the above mentioned flange has a ~85mm spacing between holes center-center. I'll get a pic up later tonight. Would that work for you?
edit: looks to be an auto only part for the zf 3hp22, but if it has the right dimensions it might be worth welding pieces together. You're close, if you want to give it a try, I can mail it.
im not a very good welder lol all i did in metals class was make ninja throwing stars. ill check the dimensions soon.
