So when I take off hard/drop clutch/shift hard there's a terrible, dull thud from the rear end. It also wheel hops until it stops clunking. I changed the diff bushing thinking it could be that, but it's no better/maybe worse now.
I finally got under the car again today and poked around a bit. I know the rear ta bushings and subframe bushings are dry rotted, but I don't see that causing this noise.
I turned the rear wheel by hand and there was what I would say is play in the diff. There was a lag between the halfshaft turning and the driveshaft turning and a clink when the driveshaft did start to turn. The only thing besides the diff I thought it could be was the CSB but I don't see that causing what I just described. Guibo looks fine.
Car is 1993 M40 5mt touring fwiw.
Should I be looking for a lsd to replace the diff?
