play in shifter??
  • spiDmang
    • 3941
    play in shifter??
    Hey fellars,
    So I recently bought a 91 318I from a couple. They stated the car has a aftermarket short shifter, but when shifting, there is a ton of play in the shifter.
    When its in gear, I can move the shifter around quite a bit. Almost bringing it back to neutral (remember, when in gear!!)
    I'm curious if this is a sign of my car needing a shifter rebuild?
    HELP! :(:curse:
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
    That does suggest that a full shifter rebuild is needed.
    • spiDmang
      • 3941
      is there anywhere i can go about getting a rebuild kit??
      • lbreevesii
        • Aug 2009
        • 412
        read the diy short shifter thread for a full breakdown of the parts. There are guides on here, pelican parts, etc. Blunttech offers a kit, as do others.
        my short list:
        pivot bushing
        foam insert for the knuckle joint
        rear shifter carrier bushing(carrier to car)
        plastic washers(yellow, 2 or 4 depending on shifter application)
        front shifter carrier bushings- highly recommend akg's delin ones.
        I don't always wreck cars, but when I do I wreck them into trees.
        91' 318is S50 swap - The Black Widow
