I need help fast, I might loose opt...
  • reztat
    • Dec 2010
    • 72
    Hi, you guys have helped me a lot, but now I might loose a big chance to fix my damn E30, some guy is selling me a 325 e 86' for 500, is in good condition just something wrong with the engine. I want to buy it for the tranny, because mine is automatic and that one is manual. But I dont know if they are compatible?, it is the same parts? or just 87 to 90? please help me...thanks in advance. I own a 325 E 88"
  • E30SPDFRK
    • 5716
    What model do you have?
    Byron
    Leichtbau
    • LJ851
      • 7919
      I have an '84 325 5 speed in my formerly automatic '89 325is. Does that answer your question?
      Lorin
      The M30 is God's engine.
      • reztat
        • Dec 2010
        • 72
        i have an 325e 88" automatic 4 door
        • reztat
          • Dec 2010
          • 72
          so 84 and up?
          • Matt-B
            The Waffler
            • 3856
            e trannys work on m50s so do i trannys so an e works on an i car
            starter needs to be match to trans flywheel though, with a little searching, you could have easily found this out
            • reztat
              • Dec 2010
              • 72
              I guess that the 325e 86" will be a wise choice then...thanks
              • e30Rooster
                • Jan 2010
                • 958
                I don't think there is an e30 I wouldn't buy for 500
                • Evilsmith
                  • 171
                  +1, even in parts its worth more than $500
                  Vert build - http://www.r3vlimited.com/board/showthread.php?t=167264
                  • scottb37
                    • 35
                    that tranny will work all day
                    • reztat
                      • Dec 2010
                      • 72
                      ok other question, that is sold, but other guy is selling me an manual tranny, I dont know from waht year, Is from a E car but he says that it will fit only E30's from 88-91, ok my car is 88 but is just the tranny, if I need to get the other parts for the swap they cant be from another year?, do they differ on something? for example flywheel,clutch, tranny bracket? thanks
