My manual tranny on my E30 has a leak at the input shaft seal, which is not bad, but regular. I'm starting to fear that the fluid in my tranny may be getting low, but I don't know how to check or fill it. Do I need a pump?
Checking/filling manual tranny fluid
You'll need a pump to fill it. You pretty much put in as much fluid as will fit. Remove the fill plug on the side of the tranny and stick your finger in the hole. If the fluid level isn't up to the fill hole, then pump some more in.Originally posted by Grueliusand i do not know what bugg brakes are. -
You fill it until it overflows; but make sure you let all the excess overflow out before you put the plug back in. Overfilling will just cause more leaks.Adam Fogg- '88 M3
Common sense- It's the new 'gifted'Comment
Just don't be like my brother. Inspired by my tranny swap, he wanted to start working some maintinence on the old eta. He did everything fine, like ryan said, and then drove around for a few days without the fill plug in, until i found it on the porch railing. :?Comment
Re: Checking/filling manual tranny fluid
Originally posted by Eurospeed88My manual tranny on my E30 has a leak at the input shaft seal, which is not bad, but regular. I'm starting to fear that the fluid in my tranny may be getting low, but I don't know how to check or fill it. Do I need a pump?
Just in the past day or two my gears have been getting harder to shift into, but also the clutch feels more spongy than usual, and requires more effort, as well as grabbing a lot lower than before.
Is this a case of low tranny fluid and needing to bleed the clutch line? Please? :)
What "pump" are we talking about?Comment
Originally posted by BeemerfanatikOriginally posted by Eurospeed88My manual tranny on my E30 has a leak at the input shaft seal, which is not bad, but regular. I'm starting to fear that the fluid in my tranny may be getting low, but I don't know how to check or fill it. Do I need a pump?
But of course check the easy stuff first, make sure your fluid is full, etc.Adam Fogg- '88 M3
Originally posted by AdamF 88iSHe's talking about a hand pump to get the oil into the tranny. Your clutch or throwout bearing may be on their way out because if they dont release all the way it will be difficult to get into gears and would also explain your funny pedal feel.
I do seem to remember a pop sound when this stuff started happening, but I didn't relate it directly to the symptoms. Any thoughts?Comment
