top pinion bearings comes out under seal after you remove the pinon gear, the pinion gear must be pressed out with proper press and set to avoid damage to threads. inner pinon bearing must be pressed off the pinon gear
LSD carrier bearings are press fit also, you will want a dial indicator and a Drag tool; part numbers for BMW factory tools are listed in the above TIS link :)
