on the shift rod one side is held on by a circlip and two yellow washers, but in a diagram the other side that is closer to the tranmission is held by o rings and a different type of circlip. Is it ok to hold the other side by the same two yellow washers and circlip?
circlip on shift rod tranny side
Re: circlip on shift rod tranny side
Thats fine, in fact thats how most of these cars are.Originally posted by zandion the shift rod one side is held on by a circlip and two yellow washers, but in a diagram the other side that is closer to the tranmission is held by o rings and a different type of circlip. Is it ok to hold the other side by the same two yellow washers and circlip?Adam Fogg- '88 M3
Common sense- It's the new 'gifted'
