Every gear is weird, help?
  • BMWerke
    • 893
    I did a tranny swap on my '90 325is, the tranny is from a '86 e325e. when we dropped the tranny in i think we bent the linkage but im not sure. since we did the swap it has been like this;
    reverse-you need to shake it as you are trying to put it in reverse.
    first-pops in with some muscle
    second-pops in loud
    third- used to pop in loud, now it grinds going from 2 to 3 but not 4 to 3. and a couple of times it wouldnt go in at all. like there was a wall blocking it so i had to double clutch and then it went in fine.
    fourth-pops in loud
    fifth-is smooth as butter
    keep in mind that there is VERY LITTLE play in the shifter so im not sure of the bushings. thanks
    '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
    '86 325e- Donor car for swap/parts car
    '00 323i- BBS 197s Totalted
    '89 740 turbo Volvo- Donated
    • 37834
    You "think" you bent the linkage? Did you look at it? Is it bent? Sounds like it may be, or your trans is garbage.
    Grover Beach, California
    BimmerHeads.com
    • Turd
      • 185
      Check your linkages for said bend(s) and make sure everything is oriented correctly. Check your bushings too.
      I had the wrong shift carrier and had the "hitting a wall" feeling trying to get into second and fifth.
      I've also dealt with sloppy bushings and had the same effect.
