I've been looking around, and I just want to be sure I am getting everything I need so I can pretend that this will go smoothly.
1 replacement diff without cover or output flanges
1 worn out diff with cover and flanges to steal from
1 cover gasket
4 new locking flange nuts (for bolts to driveshaft- getting from dealer)
2 liters diff fluid (going to use Mobil 1 75-140LS fluid)
Tools:
19mm Wrench
19mm Socket with Ratchet
17mm Wrench
8mm Allen Wrench (actually hoping to use allen socket if it will fit)
Pabst
Floor jack for gently lowering and raising diffs into position
Lift for putting car up
When I change the output flanges, do I simply unbolt from the old diff and bolt onto the new diff? Do I need to replace any seals for it? Am I supposed to mess around with the CV boots/grease?
1 cover gasket
Tools:
19mm Wrench
17mm Wrench
Pabst
