Differential cover gasket
  • rammstein
    • Jul 2009
    • 367
    Do you guys just use the little gasket by itself, or do you also squeeze a little bead of gasket maker stuff on there as well? Inquiring minds want to know.
    E30 M52B28
    I like to use a thin smear of Blue Silicone sealer. But it should seal bare.
    • giantkeeper
      • Aug 2009
      • 1416
      It definitely seals bare...just be sure to clean the surfaces.
      Always Always go for the reach around if there is an option
      • Wanganstyle
        • 2828
        I use the paper gasket naked.
        or high temp silicone like toyota around the housing- ala e46 bmw factory procedure; they deleted the paper gasket because it leaked.
        h
