6 Puck Clutch and Stock Pressure plate
  • lolcantturn
    • 4588
    Will this cause any problems? During my M50 swap I put in a Clutch Net 6 puck clutch but I retained the stock pressure plate. I still don't have the engine bolted to the car so there's still time to replace
    Originally posted by TSI
    OEM+
  • JTapper
    • Sep 2009
    • 847
    I'd go with an HD pressure plate, but that's just me.
    Why upgrade to a sweet clutch if your PP can't hold onto it?
    Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
      Due to the reduction in surface area a six puck clutch disk needs a pressure plate with higher clamping force. What you've done will probably work, but I suspect the clutch disk may not last long.
