Driveshaft Balancer
  • Goofy Footer
    • Sep 2009
    • 7
    Driveshaft Balancer
    Hello people. Is the balancer needed on the driveshaft, or can I get away not putting it on? It seems like there is something else that the driveshaft/engine need to turn, but I was told that I need not put it on after I re-install the driveshaft.
    Anytime I disconnect the forward end of the drive shaft that has the balancer, it goes in the recycle bin.I know of no negatives to removing it.
    • handysmurf59
      • 335
      Ditto to above. In fact, when I did my last clutch all of the sudden, even though it was marked prior to removal, the dampener started causing some wicked vibs in the car. Chucked it and now all is puss.......
      "But the way it deals with bumps and heaves makes you think the shocks are filled with unicorn farts and pixie tears."
