So I finished a trans reinstall which included a change of the trans seal at the input shaft, seal came out somewhat easily and went back in fine with a nice wide socket tapped in carefully.
Was taking the car to the shop to do a cat-back system and realized I forgot to reconnect the oxygen sensor. Pulled over and shut her down to plug it in, suddenly had what I assume (hopefully) to be bit of a boil over, excess trans fluid.
I had let the trans get rolled over on the wood planks I had it set on and it had lost some fluid during my work on the car. Then as I finished the job, I squooshed some fluid back in and I think I overfilled it because it was still flowing a fair bit from the fill point when I plugged it up.
It was dripping just slightly when I dropped it off... Am I on track here? I hope so... What is the "blowoff" valve on top of the trans about? Is it for this very situation?
couldn't find a prayer smilie... would really hate to take that thing out again
