Small case to medium case diff swap.... axles needed or not?
  • bad_azz_bmr
    • Sep 2004
    • 433
    Hi guys, I have been reading all afternoon on swapping out a small case for medium case diff, i have seen mixed reviews on if the output shafts need to be replaced or not..
    There are a few posts saying all diffs are interchangable, some posts say i need the medium case e30 output shafts... are the driveshafts the same?
    I also looked on the ETK and medium case vs. small case output axles have 2 different part numbers...
  • Ian Bowers
    • Apr 2008
    • 1120
    Put the new diff in. All done! I've swapped from Small to Medium case about 6 times, the only difference I've ever found is the speed sensor plug from an older diff was different than mine.
    • Roysneon
      • 4505
      Going from small in my 318i to medium from a late 325is required the output flanges to be swapped. My hex bolts rounded off when I tried to change just the outputs so I just swapped axles. Your experiences may vary.
      Originally posted by mbonanni
      I am a pursit now.
      • barry
        • 1642
        If you need shafts I have some with all new parts and no milage
        Thanks\
        Barry
          • 37834
          Axles interchange.
          Grover Beach, California
          BimmerHeads.com
          • bad_azz_bmr
            • Sep 2004
            • 433
            Thanks for the info guys, the axles bolted right up.
            LSD makes the s50 alot of fun :)
