I cannot figure this out, I have a low moaning/whining noise from 30-50mph, after that it seems to go away. My outer cv boots have some small tears and seemed to throw the grease out, i'm putting new boots on tomorrow, i've also just flushed differential fluid (no metal shavings or anything weird in the old fluid), any other ideas?
Groaning/whining noise at 30mph
Accel and decel seem to be the same as with brakes, I believe when I made a right turn it was a bit louder.
EDIT: If this was the wheel bearings, is this just the small ball bearing (looks similar to a skateboard bearing) or are these the big ball looking things inside the outer CV? I'm still not to familiar with what everything is called back there.
Ugh, rear wheel bearing didn't fix the noise, and it was a pain to do that. I have a new axle on the driver side, i'll be changing the passenger axle this weekend. I have some amsoil laying around I may change the diff fluid again with better stuff and see if it fixes this noise, if not I may be looking for a new diff.
