ZF320 oil ???
  • isra
    • 177
    ZF320 oil ???
    hi guys, i think i have a stupid question.lol
    im working on my m52 swap with speed zf320 tranny and it says in the tranny to use (ATF OIL) is it just regular (ATF) like dexron I,II,III & VI ?
    or can some one tell me the oil to use (good oil pls) and how many liters
    help pls thanks
  • Wanganstyle
    • 2828
    regular ATF oil for ZF transmission.
    manual trans oil will make ZF trans shift BAD when cold!!
    just get a big bottle + pump; of top of my head ~less than 2 quarts. capacity listed ~ 1.2-1.4 liters/quarts
    • isra
      • 177
      ok thanks for your help
      • funcrew
        • Jun 2007
        • 1223
        O'Reilly's has 3 types of transmission fluid:
        Chrysler ATF+3 & ATF+4
        Mercon/Dexron
        Type F
        Are any of these good for a ZF 5-speed manual?
        "If the sky were to fall tomorrow, the tall would die first."
        -Dr. Paul Forrester
        Do I LOOK like I need a psychological evaluation???
          • 37832
          Just the standard cheapo Mercon/Dexron also known as MD3.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • AldcE30
            • 66
            what oil does bmw run in them from the factory ?
              • 37832
              atf...
              Grover Beach, CA
              www.BimmerHeads.com
