lsd's
  • Trptguy
    • Aug 2007
    • 799
    lsd's
    i am thinking about getting a new lsd for my car. Mine is whining like crazy. I have an '87 325ic. So what lsd would be best? I am not going to track my car.
  • alB5
    • 785
    If your looking for a better gear for driving economically you should get a 2.93 off the "E" models. If not, get a 3.XX diff for more of a driving appeal.
    1991 318is -> 2004 R32 -> 2002 Jetta TDI -> 2014 FiST
    No E30 Club
    • Trptguy
      • Aug 2007
      • 799
      would a 3.25 be adequate?
      • alB5
        • 785
        Yeah they seem to be good for an M20 car. It's mostly based on what diff's you can find in your area also.
        No E30 Club
        • Trptguy
          • Aug 2007
          • 799
          yeah i found one local. I am going to try and change fluid in mine first to see if it stops the whining.
          • BMWManiac
            • Dec 2010
            • 1091
            What fluid is recommended for BMW LSDs? Redline? I went to the dealership and they only have the new stuff for the E46 M3s that come out to about $50 a pint!
            1997 Artic Silver M3
            CES GT4094r 651hp/615tq @ 24 psi
              • 37829
              Any 75w90 or 80w90 fluid is fine. You don't need anything fancy.
              If you want the "correct" ratio for the car you'll want a 3.73.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • e30trooper
                • 11576
                did it once, was a trip... O_o
                • Adrian_Visser
                  • Jun 2006
                  • 2823
                  Liquid or paper?
                  '89 Alpine S52 with goodies
                  • e30trooper
                    • 11576
                    Originally posted by Adrian_Visser
                    Liquid or paper?
                    paper
                    • LJ851
                      • 7918
                      Are you manual or auto-tragic? Stock manual gear is 3.73, stock auto gear is 4.10. For all around driving, these are pretty good ratios. M20 2.5 is not a torque monster so it needs some gear in the back to give it some leverage.
                      Lorin
                      The M30 is God's engine.
                      • BMWManiac
                        • Dec 2010
                        • 1091
                        I just bought a 3.73. As far as fluid, do I need to add the "additive" specifically for LSDs? Or just go with the normal diff fluid (redline) and don't worry about it?
                          • 37829
                          No additive is needed but Redline does make one for LSD.
                          Grover Beach, CA
                          www.BimmerHeads.com
