Getrag 240
  • Clark954
    • Jun 2011
    • 91
    Getrag 240
    Can you rebuild them, what is the max power it can safely take
    and can i put a lsd in it
  • Eecen
    • Jun 2010
    • 1235
    que?
      • 37833
      Of course you can rebuilt it.
      They are pretty week.
      I'm not sure if giving your transmission drugs would help anything.
      Grover Beach, California
      BimmerHeads.com
      • bloodshot-e30
        • 1494
        lol cheaper to keep buying transmissions as u blow them up IIRC 4th gear is $145 + or -
        ^Back in the game^
        BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
        FS thread:
        http://www.r3vlimited.com/board/showthread.php?t=214105
        • Clark954
          • Jun 2011
          • 91
          I guess I should have asked is it better to rebuild it or swap it with something else and if so any suggestions, also lsd makes it run smoother lol or at least thats what the talking bunny told me
          • bloodshot-e30
            • 1494
            LSD inside the transmission???
            what kind of power are you trying to make?
            ^Back in the game^
            FS thread:
            • Tree18is
              • Mar 2004
              • 2703
              if you need a tranny with LSD in it, go to santa monica, save yourself some cash.
              • Clark954
                • Jun 2011
                • 91
                Im not putting an lsd in the tranny I was talking bout getting an lsd and asking what are some good ones you guys know of. Again im new to the bmw world so please forgive my ignorance
                • Clark954
                  • Jun 2011
                  • 91
                  I want as much reliable power out of the m10 as possible
                  • bloodshot-e30
                    • 1494
                    so its an early 240... meh just get a used on and u shud be good unless ur goin boost.
                    ^Back in the game^
                    FS thread:
                    • Clark954
                      • Jun 2011
                      • 91
                      deff guna boost
                        • 37833
                        I'd recommend swapping to an auto tranny.
                        I love trannys.
                        BimmerHeads.com
                        • bloodshot-e30
                          • 1494
                          ^^^ lol
                          just use urs till it blows then get another ;)
                          then go boosted S54 and use the M3 trans ;)
                          but for M10 boost use the E30 M trans IIRC the bellhousing bolts up the same
                          ^Back in the game^
                          FS thread:
                          • n0n0perational
                            • Jan 2009
                            • 47
                            will the 240 bolt up to a m20 without issue?
                            i have one available to me to swap my 325i from auto to manual
                            • The Humjet
                              • Jun 2010
                              • 528
                              ^^ for your m20 you'll need a g260 off an m20 if you want the gearbox to bolt up fine on the correct angle.
                              OP Your gearbox should handle a boosted m10 just fine as long as its in healthy shape and your running a good hd clutch. Unless your after the same power as good 'n' tight is running in his m10 turbo with nitrous then upgrade to a larger gearbox from an m30 535i e28/e34 g260/6 which is perfect for stupid amounts of power
