early plate style shifter to late aluminum rod
    what all is needed to make this work?
    I have the rod and shifter from a later model, im going to get the shift arm bearing: P/N 25111220707 tomorrow.
    How does it attach on the transmission end tho?
    Thanks for any help.
    85 325e 5spd
    anyone??? do this b4
    85 325e 5spd
      To replace the sheet metal shift console with the later aluminum variant you need a transmission with the mounting ears . Or, supposedly, you can get the adapter for an E30 M3.
        do you know the part number one that?
        85 325e 5spd
