Creaking when turning/hard acceleration.
    Hey guys, I'm pretty sure it's the diff, but when I corner at low speeds the rear of the car makes groaning, creaking noises.
    I believe it's related, when I accelerate (even slightly) faster then normal people, the back of the car groans loudly and shakes.
    Time for a new diff? Change the fluid first and see what happens?
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
    Update: Solution was found!
    I changed the fluid in the Diff to Royal Purple Max Gear Oil. Took the cornering groaning away. Then I noticed car still shuttered under acceleration.
    The center support bearing was totally shot, the driveshaft was knocking against the walls of the tunnel.
    Incase anyone else has this problem, there you go!
