I found a good deal on a set of used 325 half shafts, but I cannot find a definitive answer as to whether 325 half shafts will fit into a 91 318is? I realize the differential case is different what about the half shafts? TIA.
Will 325e/i half shafts fit into a 318is?
Tags: None
yes they will work, the only ones you should watch out for are the early 318 ones with no abs.sigpic
Levent
%20levent@gutenparts.com
Ladies:
1998 E36 m3/4/5 1988 325i 1989 325iT -
