3.46 LSD .. what else? *DELIVERED*
  • Mercury[BKM]
    • Apr 2011
    • 909
    SO ive got a minty shiny 3.46 LSD on the way and should be getting here tuesday that im going to put into my 87 325e
    only problem is, Im new at this and trying to learn as much as possible so attempting to DIY everything that I feel capable of doing.
    what else do i need to do this swap right; and if i switch covers will that be enough to get it installed with relative ease?
    (if there is anyone in dallas with some free time and can maybe walk me through it, im good for a case of beer and funny banter :) )
    I can run Auto Checks on VINs for tips/donations:
    PM me VIN(s) and I'll get you ALL the public recorded info that I have available.
    paypal as gift to Mike@benzinkrieg.com
    Information/Request sticky thread for Vehicle History Reports
    http://www.r3vlimited.com/board/showthread.php?t=216119
  • LJ851
    • 7919
    If it is E28 the output flanges need to swapped as well.
    Lorin
    The M30 is God's engine.
    • Mercury[BKM]
      • Apr 2011
      • 909
      i can just cannibalize them from my current, pop the ones on the 3.46 out and mine in and call it good?
      • shiboujin
        • Feb 2006
        • 2791
        I could have sworn the E28 flanges worked fine. But regardless, yes, you can canibalize off your existing diff. The axle flanges simply pry out, no unbolting necessary.
        The general diff swap is easy:
        unbolt drive shaft
        Unbolt both axles
        unbolt the diff mount bushing from the chassis
        unbolt the 4 bolts that hold the diff to the subframe
        remove diff
        reinstallation is the reverse if uninstallation.
        • Wanganstyle
          • 2828
          unbolt drive shaft
          Unbolt both axles
          remove diff
          many e28 is big size axel flange; same as e36m3 and e34/32
          • ZM Blue Devil
            • Dec 2006
            • 13836
            Replace orings, cover gasket and diff bushings while at it.
            Levent
            %20levent@gutenparts.com
            Ladies:
            • Mercury[BKM]
              • Apr 2011
              • 909
              just standard OEM from the parts tore work well enough, or just go through pelican?
              • Bimmerista
                • Nov 2005
                • 5425
                Go through blunttech.com before you go through anyone else.
                • ZM Blue Devil
                  • Dec 2006
                  • 13836
                  Anyone but pelican. I can get you pricing as well.
                  Also have akg diff bushings.
                  L
                  Levent
                  Ladies:
                  • DaveS
                    • Jan 2009
                    • 47
                    When I put a 3.25 in my 86 es, the diff was from an E28 which had the larger flanges. Yes you can just pop out the shafts from your existing diff. I highly recommend changing the output shaft seals in the diff when you do this. I did not and two weeks later I was installing new seals. It's not hard to do it was just a PITA to take it all apart again. Also, when installing the "new" diff, install the top front bolts first. I didn't do this and I had lots of trouble getting everything to line up until I did. Good luck and it really helps to have another person working with you when you do it.
                    • DaveS
                      • Jan 2009
                      • 47
                      Sorry, I forgot. Get new circlips as well. If you're swapping the output shafts.
                      • acolella76
                        • 2950
                        L
                        just curious why you say anyone but pelican. I fucking love pelican and I know many others who feel the same way.
                        OP also replace the bolts that hold the diff to the subframe with studs, it makes installing the diff SO much easier.
                        -Alex
                        • Wanganstyle
                          • 2828
                          What length /source studs are you using?
                          • Mercury[BKM]
                            • Apr 2011
                            • 909
                            yeah what he said,
                            ill jump on blunttech and price it all out and see
                            unless i can get a better price and everything from the gentleman from Gutenparts =)
                            • Mercury[BKM]
                              • Apr 2011
                              • 909
                              UPS fucked some shit up though
                              and destroyed the diff cover
                              i have a UPS inspector coming over tomorrow to inspect and better stroke a check, gonna rebuild this now since i have no clue how bad it was jossled around (to break stuff off, it had to be a lot)
                              oh and they delivered it to a building like across the complex from me, box said apt 1121 and he drops it off at 1421 some how *sigh*
                              I will never use UPS ever again
