chatter on takeoff from rear end
  • gladesman
    • Apr 2011
    • 2
    my 89 325i just started doing this thing where it chatters when you take off. Even after the clutch pedal is all the way out if i hit the gas with any force, it starts to chatter, it does it in 1st, 2nd and 3rd. At highway speeds it drives 100% normal. I checked the diff (it was a bit loose) tightened it but still the same. The tranny mounts look a bit worn, could the tranny mounts be the problem? the rear bearings and CV joints have been replaced recently.
    Any Ideas out there?????
  • blocke
    • 1305
    guibo
    Parts Wanted
    The Never-ending Resto Mod
    • StereoInstaller1
      GAS
      • 22679
      Subframe bushings fixed mine
      Closing SOON!
      Thanks for 10 years of fun!
      • Nick325is
        • 1409
        Could be your diff mount needing to be replaced if it does it when you hit the gas.
        • Jean
          • 18228
          Could be the drive-shaft itself at the CSB joint....
