Wierd issues
  • blck325is
    • Apr 2006
    • 1749
    Wierd issues
    Recently my car started acting weird. There are a few issues, first I have had to refill my clutch reservoir about 3 times in the last 3 months. I suspect a leak but haven't checked the lines yet. The bigger issue occurs when I shift into reverse. It will start going back then the car will roll forward like its on a bungee cord.. Don't quite know how else to describe it. It has only happened twice in the last few months but it is making me nervous. Ideas?
    Originally posted by csermonet47
    Vlad, you are handling this quite unprofessionally.
    Also, you are a cock with tacky taste.
    That is all.
  • Sagaris
    • Sep 2009
    • 2243
    It seems like your driveshaft or diff might be binding up and storing energy in the driveshaft as it twists, then propelling you forward when it releases.
    • blck325is
      • Apr 2006
      • 1749
      Ahh, eff. So I should be looking to replace either the driveshaft, diff or both to fix it?
      That is all.
      • Wanganstyle
        • 2828
        that is a weird problem. try to isolate the clutch issue and see if there are any notable driveline issues- play in driveline should show it self up.
