I've removed everything I needed to I thought. 4 bolts connecting to the diff. All 6 bolts connecting to the guibo/trans. 2 bolts holding up the center bearing. I can't get this thing to drop. I spent an hour trying to get the front end off of the transmission. I've moved it around so much the guibo almost moves freely. I can move it around in circles but I still can't get the shaft to come down.
I've tried it both in neutral and in 1st, both with no results.
