LSD in a '92 automatic vert?
so funny. rofl.Easiest way to tell is not by going online and searching "does my car have LSD?" First of all, yes, it probably does have some LSD somewhere, being a BMW from the 80s/ early 90s.
To really tell, you can put the car in the air, or so that both rear wheels are off the ground, and spin them. If they spin in the SAME direction, your car had illicit drugs in the diff. If they spin opposite directions, you have no LSD, or the clutches are burnt out from excessive drifting and shit, probably by someone on LSD.
a 4 cylinder car has a 168mm size diff.
6 cylinder cars have 188mm size diffs.
you CAN plug and play them, many people have installed 188mm diffs in place of original 168mm.OBD1 M54/M52TU swap as a M50b25
