Stuff to replace when doing Short Shifter.
  • jdvorwe
    • Apr 2011
    • 366
    I am putting in a z3 2.5 shift lever in my car.
    In the Short Shifter DIY on here it says :
    Z4 2.5i SSK
    4x . . . 25 11 1 220 439 - Spacer Rings
    1x . . . 25 11 1 220 832 - Rubber Bearing sleeve (could be replaced with UUC Delrin Bushings)
    2x . . . 25 11 1 220 379 - Circlips $0.50 (one extra)
    1x . . . 25 11 1 220 600 - Nylon Shift Bushing - $4.00
    But Pelican Parts recommends replacing like everything:
    • Center Shift Bearing
    • Shift Arm Bearing
    • Shift Arm bushing
    • Shift Arm Bushing Clip
    • Spacer Washers
    • Circlips
    • Shift Coupler
    • Shift Coupler Dowel Pin
    • Rear mount for Shift Lever Support Arm
    Pelican parts list totals $100 and the "SSK" kit on here is like $20, Just wondering if I will be able to tell that much difference when shifting or should I just save the $80?
    Originally posted by trackjunkie21
    when there is a choice between an e36 and another car, you choose the other car.
    Most of the wear parts Pelican suggests almost certainly need replacing. You can probably re-use the circlips and dowel pin.
    • jdvorwe
      • Apr 2011
      • 366
      figured as much, had my shopping cart ready to go. just wanted to make sure before i spent the extra $80 that it was really needed.
      • lbreevesii
        • Aug 2009
        • 412
        I made a post on the short shift thread with my thoughts on this subject. Most of the extras you don't really need. but I would replace the circlips, the upgraded design is muchhh better than the old ones.
        fyi I have a bunch of extra clips and a couple of extra yellow washers.
        I don't always wreck cars, but when I do I wreck them into trees.
        91' 318is S50 swap - The Black Widow
        • jdvorwe
          • Apr 2011
          • 366
          Kinda looking to see what other have bought to refresh their set up when installing their short shifter
