When you are at a stop with the engine running and clutch pedal down will it positively engage all other gears?
1st gear keeps popping out. NEED HELP
yep. it slides into other gears just fine. It slides into first too but it feels funny, like sometimes there is resistance, sometimes there is a notch, sometimes it feels like i'm shifting or moving under water kind of resistance. Sorry if my analogies are ridiculous.-----------------------------------
Life is too short to be driving a Honda.
sigpicComment
i have a similar thing happening to my car, but i know its clutch related...does your pedal vibrate???? on mine gears dont pop, just hard to go into them, but if i give it a little gas it goes smooth as butter...try giving it a little gas when trying to go into first...i dont think its good for the clutchComment
i have a similar thing happening to my car, but i know its clutch related...does your pedal vibrate???? on mine gears dont pop, just hard to go into them, but if i give it a little gas it goes smooth as butter...try giving it a little gas when trying to go into first...i dont think its good for the clutch-----------------------------------
sigpicComment
here's a rundown for dummies:
SHIFT LINKAGE:
-put car in gear
-jack car up
-crawl under car
-the shift linkage is above the driveshaft
-wiggle the linkage around and look for obviously worn bushings
-if there is a lot of play, replace your bushings
TRANNY FLUID:
similar to changing engine oil
-on the passenger side of the trans there is a screw (filler screw). remove it - do this first
-there is a drain plug on the bottom of the trans (near the back)
-have a catch can ready. drain the old fluid
-screw drain plug back in
-get a fluid pump with hose attachment (http://www.autozone.com/autozone/acc...er=940782_0_0_)
-pump your favorite gear oil in
-stop when you can feel the oil with your finger (poke your finger in the hole :giggle:)
-screw fill plug back in
Do these things first and report backComment
No vibration at the pedal. I don't think it's my clutch though. it gets the car rolling when I pull the ebrake and shift into first so that tells me my clutch isn't slipping otherwise it wouldn't roll. I'm going the linkage route and oil change first to see if I notice any improvements.Comment
How many quarts of fluid do I need? Also, I have a question about the reverse. It takes quite a bit of effort to put my car in reverse. I have to really lean into it and it pops in to reverse. Is that normal on our cars~?-----------------------------------
sigpicComment
I've seen issues with the shift linkage clearing the gybo in eta cars check to see it when you shift it clears it. You'll have to have someone shift it while you're under it.Comment
Do you mean into gear, or through the reverse "gate"?Comment
Sweet. So I'll buy two quarts of Redline MTL and give it a shot. I probably mean thru the reverse gate. Is that normal still? I suppose it's there to prevent accidental shifting into reverse as opposed to 1st.-----------------------------------
sigpicComment
