Morning, all. I'm prepping my 318is for a track day at Mont Tremblant next weekend. I bled the brakes with a DIY pressure bleeder and moved on to the clutch slave cylinder, just to be thorough. When I first put the bleeder on, the line from the brake fluid reservoir to the clutch master cylinder popped off and fluid squirted all over the engine bay. The hose was cracked at the end. (10psi is actually a fair bit of pressure!) When I went under the car and cracked the bleeder nipple on the clutch slave, I got no fluid. I removed the pressure bleeder and then removed the bleeder nipple on the slave and got no fluid. WTF?
I'm wondering if some meathead put the slave cylinder on upside down: the bleeder points down. Is that correct? It doesn't *look* correct, what with air wanting to rise, and all… Regardless of this, I should still be getting fluid out of the slave with the pressure bleeder. I also found that I could open the bleeder with my left hand while pressing down on the clutch pedal with my right, and still got no fluid. So, what's going on here? There must be fluid in the slave or the clutch wouldn't disengage. Is the slave clogged, somehow?
Thanks,
Brian
Thanks,
Brian
