When reving car past 5k there is a definite vibration coming from the driveline area along with smoke and the smell of burning rubber. I'm guessing this could either be the harmonic balancer or guibo. All were replaced within the last year and slightly confused as to what would be causing this...any ideas??
Smoke from driveline
Nothing appears to have disentegrated and have a one piece mandrel system which makes removal a PITA, figured I'd ask here first.
The wire running from tranny to shifter had a wear spot and the balancer was shiny where they rubbed but the smoke that came in cockpit was quite a bit and I can't imagine it was from that...although I'm sure it played a role.Comment
