got in my car a little while ago to move it out the garage, when i pushed the clutch pedal in it went straight to floor and right back up again. it doesn't seem like the clutch master or slave cylinders are bad. i did notice that the car was very low on brake fluid. i did a disc brake conversion on the car a few weeks ago, and i guess i didn't put enough brake fluid back in
. i filled that car up with brake fluid and i tried to bleed the clutch system from the slave cylinder, but that didn't work. any ideas on what i should do?
thanks guys
thanks guys
