tall shifter?
  • bastianshaw
    • Jan 2007
    • 2210
    tall shifter?
    What kind of shifter are those really high ones? I like the idea of only moving my hand a few inches from the wheel, with a short throw Im thinking this is the way to go. Anyone running one of these? pics?
  • Ayman
    • Apr 2011
    • 4190
    paging ocrgrinder.
    Originally posted by yert315
    Your mother is plug n play
      • 37834
      I have an X5 shifter in my S50 car. Love it. :)
      Grover Beach, California
      BimmerHeads.com
      • Wh33lhop
        • 11705
        If you've got money coming out of your ears, check out the AKG DTM shifter. Get a metal ball style shift knob for it for extra sweetness.
        paint sucks
        • bastianshaw
          • Jan 2007
          • 2210
          pics...do it
          • White87E30
            • Apr 2008
            • 8
            Try a E60 545/550 shifter, its short from the factory and tall for the 5 series.
            • LuckyHenriksen
              • Jun 2010
              • 4244
              Also interested. Could you just weld/attach a longer stick to the standard short throw setup?
              Bahama Beige E23 Project
              Bluebird Bus Conversion
              New Oregon Trail
              • mdlimy
                • Aug 2011
                • 289
                There's no way to keep the throw short with a long shifter without extensive modification to the shifter assembly, the race cars you see with them have dogbox/sequential gearboxs that normally have hydrolic shifters or just a really short gear throw.
                • Jaxx_
                  • Dec 2009
                  • 1880
                  yes, you can. and depending on the ratios, keeping the standard throw and effort however elevating the shifter so it's closer to the wheel.
                  • _r2h
                    • Jun 2011
                    • 41
                    Throws on my AKG shifter are short, and it's very tall.
                    '87 325i
                    • Manimal
                      • 30
                      It's really easy if you can weld. You shorten the throw by adding below the metal ball, stock is ~1.5-1.75" from the center of the 30mm metal ball to the center of the shift linkage. I can't remember what the top is. It's just a ratio, the only problem you'll run into is shifting from 2-3 and 4-5 because it slides into gear by rotating the transmission selector rod a certain number of degrees. So, when you shorten the throw by adding length to the bottom you'll increase the side to side throw and there's nothing you can do about that short of designing a super trick shifter.
                      If you do decide to do it make sure to cut the shift rod as close to the ball as possible and do a bunch of "spot" welds. Otherwise you'll over heat the lower bushing where the shift linkage sits, it will bubble up and turn soft. Then you'll need to find a tube to weld in or weld in a rod and drill it out to 10mm. I fucked it up the first time and had to do that, it's for a lemons car so meh. I did it again for my "DD" and it turned out fine, just shortened the throw, no height increase.
                      I raised mine so the shift ball will now be about 2" below the steering wheel hub center. You'll also need(or it's a good idea with every short throw lever) to raise the shift ball cup height the same amount you added below the shift ball, that will keep the vertical stress on the selector lever rod to a minimum so you don't wear out the seal.
                      '71 2002 Agave Restomod
                      '73 2002 LeMons Project
                      '76 2002 Sleeper Turbo Project
                        That is not really true. It is common on a race car to use a short shift lever and then stick a Jaffster knob or similar on it to raise the end of the shifter. The throw gets longer, but that is good as it makes it easier to tell what gear the car in in by touch.
                        • JdmEuroNorth
                          • 222
                          Be careful of the weight of your shifter because you can prematurely wear out shift forks and synchro sleeve bushings by always having force pushing or pulling on those components.
                          Same deal with people who drive with their hand always on the shifter, you're going to wear shit out!
                          Function.
                          Form.
