Thin metal plate on trans?
  • GunMetalGrey
    • Dec 2010
    • 1499
    Does anyone know what the thing metal plate between the rear of the engine block and the transmission, I always forget the one small bolt that holds it and I end upbending it a bit, is it vital? I may need.itfor my m50 swap
  • Pinepig
    • Sep 2007
    • 1811
    It's just a dirt/rock shield. Straighten it out best you can and use it.
    • A_Whelan
      • Jul 2010
      • 691
      I'm sure Janderson will pop in and explain the importance of it because it held his build up for a while.
      Short answer: Yes. It is important, it stops a lot of unwanted dirt and shit from getting up in there. And if you have the time you could order a new one, they are under $15 if I remember correctly.
      r3vlimited Lanyard Group Buy!!!
      • Dominic49
        • Feb 2007
        • 1373
        it aligns the starter as well, its slightly important
        • AndrewBird
          The Mad Scientist
          • 11898
          It acts as a shim to space the transmission (and therefore release bearing) the correct distance away from the engine (and therefore the clutch/pressure plate). So yes, it is need. I would just try to bend yours back as best you can, or just buy a new one. They are cheap.
          • lolcantturn
            • 4588
            I don't run one. Meh
            Originally posted by TSI
            OEM+
            • DuMa
              • 1101
              floor diffuser.
              • Vtec?lol
                • Dec 2009
                • 3278
                I haven't run one for a while but it does seem to make my TOB noisy as hell so when I swap motors it will be back on.
                (...you need it)
