Parts to freshen up Getrag 260
  • Tico Frank
    • Feb 2011
    • 351
    I searched and couldn't find an answer so here goes. I have my transmission out while I prep the engine for my m50 swap and want to know what parts should I replace while the g260 is out. I don't have a ton of money to spend and also want to avoid getting to deep into the transmission so I am just thinking wear parts and seals.
    Thanks
    Without the tools and specific expertise needed, the best you can do with the transmission is to replace all of the seals.
    • scottinAZ
      • Dec 2009
      • 1312
      best thing you can do on the G260 is replace the shift shaft, output and maybe input seals. Past this it requires splitting the case, at which point you would be better off using a different transmission....
      I saved 15% on my Bimmer parts by switching to ...
      • Tico Frank
        • Feb 2011
        • 351
        So far recommendations are Shift Shaft, Output and input seals. Anything else?
          That is it. Though I will always throughly clean the transmission while it out and I will always replace the clutch fork pivot pin.
          • Tico Frank
            • Feb 2011
            • 351
            Seals, clutch fork pivot pin, shift shaft.
            • bastianshaw
              • Jan 2007
              • 2210
              good question op thanks forthe replies
              • bmwguy325is
                • May 2011
                • 1263
                Change the fluid kinda a given but still
                sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                • Pennyw1se
                  • Jul 2009
                  • 121
                  Detent cover. Mine is/was leaking. I'm told they tend to warp with heat.
                  Part number 23-31-1-228-470
