shift linkage or bad trans?
  • AsharC
    • Jun 2011
    • 1508
    My cousin is buying an e30 and the owner said he was driving in 4th on the highway and went to put it into 5th and wouldn't go into 5th and now its just stuck in 4th gear and the shifter just moves around. Is it the linkage or the trans? The car is a 91 325i, so it has the late model shifter, not the early model arm.
    Thanks, all help is appreciated
    BUY MY WHEELS! BBS E50s!!
    http://www.r3vlimited.com/board/showthread.php?t=275407
    Originally posted by Lurker27
    Any man will tell you being blown is better than being stroked.
  • scottinAZ
    • Dec 2009
    • 1312
    could be either one, best way to find out is to get under the car and take a look
    I saved 15% on my Bimmer parts by switching to ...
    • M-technik-3
      • 18946
      eS so it's most likely still a plate style shifter. Loose one bolt and the thing goes seriously off kilter.
      • nrubenstein
        • 3148
        If the shifter just moves around, it's almost certainly the linkage. As I enjoyed the other day when the joint came off the transmission. I guess the fucking retaining clip broke.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • AsharC
          • Jun 2011
          • 1508
          I though it was the linkage also, but ill have to check it out.
          • agile30
            • 832
            Check the bitch clip. Mine popped off somehow while driving one day and I ghetto rigged it but its a simple fix.
            Originally posted by Good & Tight
            It takes real man to mount a big woman, all you haters are just scared boys.
