Trans cooler for F/I E30
  • kamotors
    • Nov 2007
    • 7102
    Well my E30 is automatic and turbo charged and I would think that the factory cooler that is built into the radiator is likely not up to the job any more. I would like to setup a transcooler than can outperform the stock one. A transcool is very cheap and easy to setup but I need some help on determining the size I would need. I will be installing it directly behind where my fog light and brake duct are on my driver side. Also is it possible to run a cooler in line with my factory trans cooler? as in have the stock line run to the radiator,then have the return line run into an aftermarket cooler and then run back to the tranny? or would the added length of line cause issues?
    I'm thinking of a cooler similar to this
    or this
    and behind my driver side brake duct
    7speedshop.com
  • Sagaris
    • Sep 2009
    • 2243
    I would run synthetic ATF if you don't already. The trans cooler is a great idea. Are you running A/C? I am wondering if the trans pan from the ZF 4hp22 equipped jags and land rovers is any deeper. A deeper pan with more fluid capacity would certainly help with cooling, but running a cooler will also increase fluid capacity.
    • kamotors
      • Nov 2007
      • 7102
      just did more research I will be running it in series to the stock cooler. I have a filter kit coming from pelican parts and I will likely run synthetic ATF now.
      7speedshop.com
      • Sagaris
        • Sep 2009
        • 2243
        It may be worth reading up on some hot-rod forums/sites to see if there are any drawbacks associated with the added pressure drop that another cooler might bring.
        • kamotors
          • Nov 2007
          • 7102
          from the research I've been doing there doesn't seem to be any drawbacks, very few people run them separately, the risk of running it separately is that you risk the new cooler not being up to the task if its too small.
          heres an example of an inline setup
          7speedshop.com
          • Sagaris
            • Sep 2009
            • 2243
            Sounds good, all that I can suggest is that you run it Bosozoku style out front like the lot of high performance driving machines shown here.
            • kamotors
              • Nov 2007
              • 7102
              lol, no thanks
              7speedshop.com
              • kamotors
                • Nov 2007
                • 7102
                It seems obvious but i want to make sure.... is the top line on the radiator the oil feed and the bottom would be the return? I will be using the B&M super cooler.
                7speedshop.com
                • kamotors
                  • Nov 2007
                  • 7102
                  anyone know what threads the ATF cooler lines are on the factory cooler?
                  7speedshop.com
                  • kamotors
                    • Nov 2007
                    • 7102
                    Does anyone know whether the threads at the radiator to cooler lines are M16 or M18?
                    7speedshop.com
