Simple question:
Does a clutch on a dual mass flywheel wear less than with a single mass flywheel?
The reason I ask is because in a twin mass setup, there is a little "give" with the engagement due to the twin mass flywheel. In a single mass, there may or may not be springs in the clutch.
But generally, what are your thoughts? Is there a difference?
