Hey everyone. I'm preparing to manual swap my car but I need to replace the input shaft bearing. I looked at the new bearing and it looks like it has a cir-clip going around the bearing. does that mean that the bearing cannot be removed through the bell housing end of the transmission? Any tips on this and if I do need to pull apart the gearing side of the trans is there anything else that should be replaced? Thanks.
G260 input shaft bearing removal?
Get a Bently manual. I am pretty sure you have to break the case open. Which requires special tools.sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
